Mugabetown - Whoretownin' At It's Worst.
That many?
New car is fast. Fast car is fast. Nearly scary fast. Will be even faster with bigger injectors and more boosts. Injectors are pretty much maxed out atm.
Edited by MagicMikeZ32
How many kw's are you guys making at 4k rpm?
Out of interest...
no efffffin idea Mike.
-5s on standard 26 are very sluggish and would not be surprised if a Honda Civic goes faster than me at 4Krpm
Out of interest...
Mine was 225kw last time. That was its base tune with the new ecu still limited to 4k, hoping to get a lot more when i can run some timing and boost
What turbos Bunta?
Makes for a fast streeter making that much so 'low' in the rev range...
HKS 2510s with a few select twists courtesy of MTQ, and yeah its pretty much perfect for street duties.
Edited by Bunta
*WOW* great numbers that is @ 4k rpm
Yep, pretty happy with it, will see what the final result is in the end.
2510's are pretty small...
What kind of peak numbers are you looking for?
yeah they are small, as for peak figures I couldn't really care less, I just want a huge midrange, peak figure so far is 306rwkw at 14psi with very little timing, given the 'bastardised' nature of the turbos I have no idea what they are capable of.
I understand why the need for a stroker would suit you.
    • R34DE as in R34 with an RB25DE? So did you get this? Or you planning to?  I'm not really sure what you're saying.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
