Mugabetown - Whoretownin' At It's Worst.
Scotty we have a car in ATM with this bit broken off
The cas is perfectly fine if you get it in the right tooth
Just get a timing light and chuck it on and make sure it's in the right spot before...... Giving it to it
It should be fine that way even with the broken half but it's completely up to you of you want to replace...... Then I buy cam :devil:
Yeah after a lot a research and asking around Ive found this is actually pretty common
It isn't that expensive, not in the grand scheme of things. And not when you are betting your engine against a 20 year old CAS. Knowing what I know now, a crank trigger and appropriate ecu would have been among the first mods to every skyline I have owned
I definitely agree that its a far better option. If i had the money I would make the change.
Potentially, but more reliability is the real key.
Reliability is always key when making good HP
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
    • Hey mate, really appreciate the help. Have been looking pretty extensively myself and was certain they were retro fitted, but then ended up finding a 4 door with what looks like the same side skirts or at least the closest I’ve seen. The photos from the Offset Kings event at Sunrise 2016. https://fatlace.com/offset-kings-okayama-at-sunrise/
    • Isn't there a PAR engineering gearset that has closer to stock ratios? And they claim they'll do whatever ratios you want.
