Mugabetown - Whoretownin' At It's Worst.
Good to hear Martin!
Not going to be driving her on the road till i get the billies back in, but at least I can move her out of the garage now!
I adjusted the clutch free play too and it feels a lot better. Still needs new fluid and a bleed though I reckon.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
