Mugabetown - Whoretownin' At It's Worst.
agree 100% percent.
Maybe it was a dude that kinda looked like Taylor Swift
Haha probably!
I other news I managed to swap the r33 exhaust I had for a r32 gtr exhaust that actually has a mid muffler in it. I don't have to mess around moving hangers this way. Quieter unicorn here I come!
Doesn't take anything bad for one to accidentally go to fast for a corner, at which point continuing on the path of the road is no longer an option. I just got lucky.
edit: wet weather doesn't help.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
