Mugabetown - Whoretownin' At It's Worst.
I'm thinking 33 because it's all the same and it gives me a chance to refit some stuff I want
New motor I could put in one and make track pig
As some one who has done the engine swap thing I can say it's a pain in the ass and sticking with a r33 is by far your easiest option
Morning all
My grandad if looking at options for the car and is sending me all this stuff
So he has found a 34 front end conversion kit got under a grand. And door and rear quaters off a black gtr for 200
Morning all
a 34 conversion would be cool but Id keep things simple and stick to the same model make as conversions are costly after you include lights, fittings, cutting, taking rear qtr panels and welding them back on, sanding and respraying......it's a bigger job than just acquiring a body kit.
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
