Mugabetown - Whoretownin' At It's Worst.
I'm thinking 33 because it's all the same and it gives me a chance to refit some stuff I want
New motor I could put in one and make track pig
As some one who has done the engine swap thing I can say it's a pain in the ass and sticking with a r33 is by far your easiest option
Morning all
My grandad if looking at options for the car and is sending me all this stuff
So he has found a 34 front end conversion kit got under a grand. And door and rear quaters off a black gtr for 200
Morning all
a 34 conversion would be cool but Id keep things simple and stick to the same model make as conversions are costly after you include lights, fittings, cutting, taking rear qtr panels and welding them back on, sanding and respraying......it's a bigger job than just acquiring a body kit.
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
