Mugabetown - Whoretownin' At It's Worst.
I'm thinking 33 because it's all the same and it gives me a chance to refit some stuff I want
New motor I could put in one and make track pig
As some one who has done the engine swap thing I can say it's a pain in the ass and sticking with a r33 is by far your easiest option
Morning all
My grandad if looking at options for the car and is sending me all this stuff
So he has found a 34 front end conversion kit got under a grand. And door and rear quaters off a black gtr for 200
Morning all
a 34 conversion would be cool but Id keep things simple and stick to the same model make as conversions are costly after you include lights, fittings, cutting, taking rear qtr panels and welding them back on, sanding and respraying......it's a bigger job than just acquiring a body kit.
