Mugabetown - Whoretownin' At It's Worst.
I'm bored and proposing names for zacs new car
So far "The Lovechild" winning lol
Goon Balloon Mk 2.0...due to it being another Goon Balloon complete with boat trailer indicators.
Second day driving the GTR was really nice.
I forgot how low the car is and managed to pop out the passenger indicator out of its place.
The indicator still works but the mounting point is well........
*Le f**ked*
I have just ordered a new one.
Been an expensive day today with quaife diff and whiteline bushes :/
Well done mate. Looks good
So glad your back out driving this thing now... TIme to enjoy it and rack up them KM's
Do you have an idea of when you will be back for another tune and some E85? or just enjoying it for time being?
Decisions..... For a decent 34 it's 15 and for a amloast destroyed 33gtr it's 14
This makes it hard because either way I will be fixing stuff and changing, and of it's rooted I can fix it so not to much there, and will have a new engine either way....
Hmm
Hmm
I thought that we were just looking for a 33?
well with E85 being so close to me I would like it to be on E85 now.
But it would be best to give it km's first and then once I think it's done enough (maybe 3,000km, so another 2,400kmto go)
Certainly am enjoy it FTM :) :)
But it would be best to give it km's first and then once I think it's done enough (maybe 3,000km, so another 1,500
I agree with you here. Give the motor a heap of KM's on pump98 then give it some e85 when run in has finished.
WHat ECU is it again ? Can it be flex tuned
Hmm
Buy my leopard. Put 33 stuff in it. Massive win.
  • Like 1
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
