Mugabetown - Whoretownin' At It's Worst.
I agree with you here. Give the motor a heap of KM's on pump98 then give it some e85 when run in has finished.
WHat ECU is it again ? Can it be flex tuned
Yeah thats the idea Scottie.
ECU is Haltech Platinum Pro so eflex is also on the cards ;)
Decisions..... For a decent 34 it's 15 and for a amloast destroyed 33gtr it's 14
This makes it hard because either way I will be fixing stuff and changing, and of it's rooted I can fix it so not to much there, and will have a new engine either way....
Hmm
Grant (Count Grantleyish) is selling his R34 GTT it is really nice - think 14k IRRC.
But he is in VIC and communication may be difficult as he can't hear but give it a try Zac.
Thought it was. Well yeah few hundred $$ for the sensor and you're all sweet. Though with E85 so close there's a fair chance it may never see pump98 again after the tune. But its good having that piece of mind that you "CAN" run 98 if you decide to
Don't forget $$$ for the retune also.
I'd be interested to see how a car tuned on E85 would run off boost at highway cruising speeds on 98. It'd be running rich, but i would presume not enough to cause it not to run?
exactly mate. If I want to. But will no doubt be very reluctant ever put 98 after considering its power potential :woot:
I drive mine from Caboolture to QR quite often. It runs perfect. chews through a bit of fuel but thats expected
If it was a E85 only tune run on 98 running rich would be the least of your worries, the timing advance on E85 is way beyond what an engine on 98 can handle and that's why the flex sensor is important
not that I want to rub it in, but yesterday I spotted another United that has E85 which is close to my home
I have to say that it will soon become more readily available near you too Bunts
Would there really be that much timing at low revs and low load though?
There's no United servos north of the Logan motorway and south of chermside. Not no servos selling E85, no servos at all. :(
Wow I totally misread what Peter was saying lol.
I wouldnt want to chance it. Considering i gained 100-110hp changing from 98 to e85 with only 2-3psi more, there is no chance I'd risk running any fuel my car wasnt tuned to fun. Hell I didnt even like putting anything but BP Ultimate in my car before i went e85..
In regards to servo locations. I guess Brendale is closest then. But it is slightly north-er than Chermy
From my understanding yes, thats why E85 cars often feel like a big capacity NA while cruising around, and while you are cruising it might be ok but the second you put any load on it, say a hill, you would be in the shit.
this is what I am currently doing. Will not put anything else in car except for BP Ultimate until it is tuned on E85.
Why take the risk if you don't have to?
ah, ok then. 20l range extenders it is!
next question: tuned on caltex e-whatever, run on united? Caltexs range is lacking out of the cities but there's a nice chain of uniteds around
If I were you Peter I'd stick to United. The consistency they have is well known amongst e85 users. They always have a well controlled Ethanol content. Caltex has been knows to drop as low as 70% ethanol, this is a major issue if you dont have a flex sensor.
Also its worth noting that the V8 Supercars this season have in fact ditched Sucrogen E85 in favour of United E85. The same we get from the bowser just "Controlled" tighter to make sure all teams are getting the exact same blend
Either way you decide to go, its always best to get it tuned on the exact same fuel your going to run. Why tune on Caltex if its going to run United?
and their goes another.............
http://finance.ninemsn.com.au/newsbusiness/8823843/300-jobs-lost-as-bp-shuts-brisbane-refinery
Australia's manufacturing industry is in server dire straits.
The correlation between the costs of living and wages needs to be addressed soon, otherwise, Australia is facing a manufacturing sector that will be almost 100% outsourced.
not good.
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
