Mugabetown - Whoretownin' At It's Worst.
Scott's old bumper cleaned up and fitted! 4 friends cars impounded over tambourine yesterday :( too low and crossing white line instant 7 day impound
Nice one. Not so nice...
You can cross a white line to give way to cyclists though... Interesting...
Fairly sure they can fight that, you are allowed to partially cross a white line.
by the time they try to fight all of that 7 days would of passed.
Whether they can put a case together to fight infringement penalty cost is another matter
I would be fighting because the next impoundment would be 3 months.
To make it worse only 1 of the cars was borderline low and they were going about 40kmh due to heavy traffic :(
so out of all the other traffic they got picked out of the bunch and impounded???
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
