Mugabetown - Whoretownin' At It's Worst.
that makes me cringe when you say that
Ain't nobody cutting my boyz off.
I want to use them as much as possible - but no more kids
They're still there Ants...just stops the sprogs coming along.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
