Mugabetown - Whoretownin' At It's Worst.
Since i'm a young middle class single guy with no children this budget pretty much doesn't effect me. Some changes to HECS repayments for 2015-2016 but hopefully that'll all be paid off before the end of the decade and the effects will be minor.
This I like
MPs super freeze
The Government has made a submission to the independent Remuneration Tribunal proposing to freeze the salaries
and allowances of parliamentarians (MPs), departmental secretaries and all other public office holders at current
levels for 12 months, over the period 1 July 2014 to 30 June 2015.
The freeze will also apply to the pensions of
former parliamentarians received under the closed Parliamentary Contributory Superannuation Scheme.(Source:
Budget Paper No 2 [p 70].)
Now to introduce MP's salary caps
This I like
MPs super freeze
I got told off by a greens MP on Twitter. This makes me feel selfrighteous and confident that I'm doing the right thing. If you're pissing off the greens, you're on the right path. ;-)
Yeah for once I seem to be one of those who will be least screwed by the latest budget.
Can't say I'm that upset about most of it TBH. Welfare cuts have been needed for a long time.
Pension age of 70 is a bit rough but by the time I get to retire I expect there will be no pension at all, so meh.
What's magic mike going to be upset about? Rich b*stard have to pay the defecit levy?
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
