Mugabetown - Whoretownin' At It's Worst.
Or you could just have a big bender :P
I still very much want to organise an SAU Scotch nite.
Been thinking of renting a place in between the GC and Brisvegas - something nice but not over top
What's wrong with Casa De Ants?
Sure, you can race in mine and I'll race in yours.
in due course Mikie
I've always wanted to do circuit racing - but just like everything else I want to learn how to drive first before I go out all gun-ho and crash it
in due course Mikie
Learn in mine and I'll learn in yours :P
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
