Mugabetown - Whoretownin' At It's Worst.
Agree with that. I got an s5 a few weeks ago. Battery life is amazing compared to anything else ive had. I can get 2 days of use out of one charge.
I was tossing up between the S5 and Note 3, but the bigger physical size of the note I liked more. I enjoy being able to customize pretty much anything with android phones. Iphone's are too structured and you cant change a whole lot looks wise with it unless you jailbreak it
  • Like 1
Not that I'm an expert on phones or gadgets but just like everything else I think battery life of any mobile will essentially become worse and worse over time.
A lot of peeps are moving towards S5, even my Father recently got one - though he despises it.
I will retain the iOS for now - because I know it works for me.
Samsung FTW. I am on my 3rd now. I am also loving my Note 8, actually everyone loves my note 8 after I started using it at work 4 other people in my team went and bought one!
on your third? How long do they last you?
Mwahaha, success!
10426519_644780528949375_1715090444_o.jp
Also does anyone want a Z145A?
Also, upon closer inspection, the PWR intercooler would probably fit, its just a more vertical orientation than the standard item. Pulled the trigger on a Plazmaman one though.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
