Mugabetown - Whoretownin' At It's Worst.
Well I went to boarding school so sort of left at 12, BUT my family has well over 100 years of history there, so all of the influences in my life are from the area.
So you learnt english at a boarding school :P
I did go to school for 7 years before that, and got an academic scholarship, so really I would think I knew much of it before I got there! My mum was a teacher, so I learned most of it from her, but she was also from Gatton! Nick and his Goonie mates are giving the place a bad name! :P
Though I must say my brothers wife and kids do a good job of that too! Haha
Too much stuff in a legnum engine bay.
Removed most of it though, thing is only hanging by a pair of engine mounts for tomorrow
SAU needs to do more group mechanic days though
We do.... It's called a reshell... And subframe bushes.... And anything that I really do on my car I invite people to come look at and learn
I'm gonna try coax the boss into letting greggo use the hoist. Feel like a super shit bloke that he can't
You just need to get on your knees and 'beg'
who has access to hoist or something to lift the dirty 33 up. I need to do exhaust manifold gasket ......... will pay !
looking to do it on the weekend of the 14/15th if possible
dude. Get some jacks and ratchet spanners and you are all good
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
