Mugabetown - Whoretownin' At It's Worst.
Mangs, scrackin in here?
Can somebody FAST this vin number for me?
6U9000BNR32221349
Thanks :D
Model: KBNR32RXFSAA
Model Series: R32
Date: 09/92
Colour: TH1
Interior: G
Body: 2K (2 door Coupe)
Engine: RB26DETT
Badge: GT-R
Trans: MT.F5 (Manual 5 speed)
Steering?: HI.4WD (Hicas 4WD)
Love you long time
    • How many of you guys run the synchro os giken set and at what power? Do you then also use the billet plate?  How is it launching with it, any dragy times from 0-60? 60ft?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
