Mugabetown - Whoretownin' At It's Worst.
Hello, still intending on coming to the sprints just won't be there till laterish.
And yes just to confirm "blind Nick was blind"... Yes, yes I was lol. Ended up down town doing ouzo shots :P
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
