Mugabetown - Whoretownin' At It's Worst.
Wow, much fail, such broken
Many sads were had :(
On a different note, fastest times of the 4 runs:
  1. Daniel Reardon 0:56.5941
  2. Ben Duncan 0:56.8389
  3. Adam McLeod 0:58.1254
  4. Paul Mienert 0:59.0399
  5. Jon Consoli 0:59.5764
  6. Alex Bradford 1:00.9891
  7. Noel Teelow 1:01.1596
  8. Dan Rule 1:01.2492
  9. Jackson Madders 1:02.2065
  10. Greg Sutton 1:02.5287
  11. Sarah Lawson 1:02.7827
  12. Dylan Bigg 1:03.0922
  13. Michael Cadman 1:03.2892
  14. Courto Cowan 1:08.4993
  15. Joshua Jones 1:087293
  16. Captain Slow 1:11.2470
Right where you wanted to be Cadmoon. Well done!
Thanks, yeah I was quite happy with it. Next step now is suspension work then some more power. I almost cracked 1:02 on the 5th session.
  • Daniel Reardon 0:56.5941
  • Ben Duncan 0:56.8389
  • Adam McLeod 0:58.1254
  • Paul Mienert 0:59.0399
  • Jon Consoli 0:59.5764
  • Alex Bradford 1:00.9891
  • Noel Teelow 1:01.1596
  • Dan Rule 1:01.2492
  • Jackson Madders 1:02.2065
  • Greg Sutton 1:02.5287
  • Sarah Lawson 1:02.7827
  • Dylan Bigg 1:03.0922
  • Michael Cadman 1:03.2892
  • Courto Cowan 1:08.4993
  • Joshua Jones 1:087293
  • Captain Slow 1:11.2470
the top five drove what cars Mouse?
good stuff - I thought you had pulled out?
I am, I would have gone out to see everyone today but I had to work unfortunately, but looking to send my 31 to Chris very soon to sort out this silly problem with it and have it on the road when I get my tax back
Sweet. A little more power and a few of the right suspension mods will see you close to a minute.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
