Mugabetown - Whoretownin' At It's Worst.
Something to do with the injector upgrade :( Might have disturbed the 20+ year old wiring :(
Z32 injectors are constant 12v, and fire when earthed, so possible that there is an earth leakage somewhere :(
I hate electrics :(
I hate electrics :(
That's such a stupid way to fire...silly Nissan.
Could buy like 5 33's for it.
A mate bought a 33 last weekend, cost him 4k I think. Pretty decent stock condition with just a cat back. Paint a bit average.
Sounds about right for a rough stock one.
Afternoon all. Diet is going well, haven't died from it as yet. Food is actually quite tasty :)
Mike, have you tried dropping the 555s back in and seeing how it idles then?
Want to avoid doing that until I have exhausted other options, as I'd have to re-cut and re-solder the connectors again to old style.
Fair enough then. Are any of the injectors faulty? I guess you won't be able to tell unless you pull them out.
    • There are black hose clamps as well if you care. Plazmaman for example sells some: https://plazmaman.com/product/black-hose-clamps-premium-quality-stainless-breeze/
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
