Mugabetown - Whoretownin' At It's Worst.
You will only ever know if you have a go Mel.
Italian food here is well spread out IMO
Quality of Italian food may on the other hand is a different story
Very good Italian restaurants on the GC and Brisbane
I mean real italian not yeah we are italian nooo your food tastes like dirt...
There are two Italian places I REALLY enjoy and one is GC the other is Griffith, there is an italian Pizza place near my place that does awesome Pizza too but they only do Pizza and maybe one or two pastas and it's take away...
RE: schools.
My main point with this is generally kids of the wealthy or people with influence tend to go to private or more exclusive schools so the chance of meeting kids who have successful/influential parents is much higher than in Browns Plains State High where I went to school. There is no substitute for hard work and good support from family. There are plenty of deadshits in any school but as a percentage game there are a lot more opportunities that private school kids get that wouldn't even be on the table at public school.
If I had a kid I'd want to give them every advantage I could to get ahead.
Agree with you Colin, It also depends on the kid...
I would have done really well at a school where I had more options instead of a school where our choices were limited because they didn't have the students to make up numbers for a range of classes so we kinda had to do subjects that we were given (doesn't help there were about 400-500 kids total in grade 7-12, primary school was 30 kids K-6). Zane thinks for him private school was a waste because he went out and became a tradie and has no interest in anything more than possibly another trade, not interested in a management position just a standard trade position. My brother is ridiculously good at what he does, on a very healthy wage and has given presentations multiple times for Google and Microsoft over in the states but he can't attribute any of that to school because it's stuff he researched outside of it.
No Skyline until Monday :(
6am tunnel runs on Sunday anyone? :D
2 cameras on the way through, smile.
At that time of day you take about 3 minutes longer to just go via the ICB.
Not to mention the tunnel under the RnA is better for a blast
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
