Mugabetown - Whoretownin' At It's Worst.
I am in a happy mood for a Monday becuase my car goes to Chris this arvo... Then German Club Wednesday then Zac/Greg are working on removing HICAS on Saturday so hopefully that means it will be a pretty good week...
sounds like you have the boys doing exactly what you want them to do lol
Haha, they have more of an idea then me... I kinda know what needs to be done but chances of me successfully doing it without them are low, especially when they go and confuse the shit out of me explaining things when I am not looking at the car... What I thought I knew turns into NFI which turns into well I wasn't too far off before I got confused so that's good!
I know Mel.
I was just stirring.
It will be good to see how different your car behaves with the lock bar in place.
I'm gonna wait until I get all the key suspension part for the Ant-Eater then install the lock bar at the same time.
I know Mel.
Haha I know that's why I LOL'd ;)
Yeah it should be good, Martin will judge the difference at Happy Laps I am sure!
Lock bar will (should) require an alignment after install
Yep, it's happening on Saturday
Gah I have lunch at 12:00 and the boss is going to get our lunch and was meant to leave at about 12:15 but she only just left... SO... SO... HUNGRY!!!
Borderline Hangry!
or angry hungry?
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
    • Keeping in mind that for most people this is a week to month long job!
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
