Mugabetown - Whoretownin' At It's Worst.
Spiders are ok. You just slap them and they die. And spiders never tried to murder me
spiders, snakes are all eeky and I'm not afraid to admit that they creep me out - especially spiders they are just fugly
if Gawd had blessed those creatures with better looks I probably wouldn't think like that either
Looks can be deceiving though lol
Snakes have never tried to murder me... I have had bad experiences with spiders, I was scared before that but after that nope!!!
Spiders are horrible, they are my biggest fear, closely followed by thunderstorms... Cannot handle at all...
Nah I was referring to being drunk as hell last week when out. Had fun and would love to be doing again this week but I would struggle real bad for the next few days!
its called getting old Bunts lol
    • No. Only for a standard ECU with/without Nistune. Standalone has no need for it. That's like the 3rd time I've said so.   And as to that sensor linked - yes, it does look like it would be the right one. I've never bothered to see how available they were - just assumed that they'd be hard to find. I think I'd be planning to go Link ECU rather than buy sensors I don't actually want to make Nistune work, if I did not already have Nistune. As you do not already have Nistune, you should realy consider your options.
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
