Mugabetown - Whoretownin' At It's Worst.
Hmm, someone selling a set of 33 brembos for $1800 bucks. Seems a bit steep...
Pete - get on it
http://www.ebay.com.au/itm/R33-GTR-Front-Brembo-Brakes-JDM-Nissan-Skyline-Drift-Silvia-/321333757526?_trksid=p2054897.l4275
you could also pick it up since your in Brisvegas
What's involved in fitting 34 items to 32?
you either have to put inserts in the caliper to take the bolt size down to 12 mm and use the r32 bolts or drill the hub out to 14 mm and use the r34 bolts to mount the caliper
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
