Mugabetown - Whoretownin' At It's Worst.
I have had a similar week Mel. Forgot my go card and work keys on Monday, forgot my wallet Tuesday. Luckily I have today off to reset a shite week!
My day off is Friday because we work all over the place and the other wanted a long weekend which I don't get anyway, I haven't had a good few days although didn't totally suck at Indoor last night, I actually hit some and left the ones I didn't need to hit :D Had a higher score than Martin temporarily, until I got bowled twice and ended up with the same amount of runs haha... I didn't realise in indoor as long as I moved the bat to look like I tried to get the ball I could use my body to block the stumps lol
Bonjour Mel!
We kinda needed one quickly as I was getting sick of driving my parents ute
I will give the 6 an Antz special detail and she will look incredible
Want to give mine a special detail? She needs more than that tho :P
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
