Mugabetown - Whoretownin' At It's Worst.
That reminds me, I should ring the dealership and remind them I dont want their rubbish electronis rust protection and 'nano technology'
Oh no, you can't possibly buy a new car without that! :rolleyes:
They didn't even try to sell me that. Feeling left out now
Maybe you had already subtly already told them to GTFO with the unnecessary overpriced extras?
Or you had a shit sales person :P
I'd give ya some tissues for your tears but real men don't use them so I have none to give you
Surely you have a spare white flag lying around somewhere I could borrow? :P
Naah he was pretty good actually, he even told me not to buy tonneau/cannopy of them because they were overpriced.
...OK, maybe he was pretty sh*t, from nissan's point of view. :P
I think they looked after me because the sale was organised through my sister's work (big salary packing company, major buying power)
Electronic rust protection is the shit though...
Heard mixed reports. Some people say it is uterly useless, others say it is great. Not sure what to beleive, but none of the science is very convincing...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
