Mugabetown - Whoretownin' At It's Worst.
Same. Anrtz...why you no run for pres?
Because I would be a horrible one.
My time is limited with having a young family FTM
Should I ever be honoured to represent the face of the club, I would want to ensure I can commit and adhere to its responsibilities before hand, otherwise it's not fair to anyone involved (with the club) and I don't want to let you guys down
But as the kids are getting older and more independent - I would be happy too
That sux Mel.
Hope you get that shot soon
Well bed time.
Nite all
Theoretically it will arrive at 5pm... Touch wood it turns up because otherwise I'm cutting it realllly fine lol
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
