Mugabetown - Whoretownin' At It's Worst.
I've used this guide for removing the hicas on both my 32's and it works great and is the easiest way to stop the warning light showing on the dash.
http://www.sau.com.au/forums/topic/410492-r32-hicas-removal/
HICAS warning light
Many people have said that locking HICAS causes your steering to get heavy, but they simply haven't done it properly. There has been NO change in steering feel with any of the cars that I have done. The only problem is the fact that the HICAS warning light comes on (because it's not there...). This can be solved by cutting the warning sender wire on the HICAS computer or removing the warning light's bulb from the dash. I prefer to cut the wire as it's quicker, easier and if you for some reason lose power steering fluid, it will tell you when your resevoir is low.
The HICAS computer is underneath the parcel shelf, it is to the right of centre (when looking in from the boot). Unplug the smaller of the two plugs in the back of it and then cut the green with white trace line wire. You can also just leave the smaller of the two harnesses out and it does the same thing, no ill effects and no HICAS light.
HICAS warning light
easy peasie
How is everyone?
I did some landscaping yesterday, my muscles hurt... Thankfully not as badly as I thought they would, I can still function haha! But even my hands are sore! So what do I do? Arrange for 2m3 of crusher dust and pebbles to be delivered today so I can do that along with the other garden edges I need to do :P Never learn!
    • Finally have an update on this  Rack came in this week so I did a test fit. You do need the S chassis bushings since the rack is 5mm thinner than the R33 rack. The main issue I foresaw and ran into was one of the hardlines not lining up properly with there it's meant to on the rack. After some gentle coercing and bending very slightly, I managed to get it to fit without any kinks and keeping the hardline pretty much in all of the factory mounting positions. I did have to unbolt all of the soft mounts to move the line around so I could snake it out and bend it safely but it looks good to me for now. I'll update when the rack is fully bolted in and functioning.
    • I hear this thread needs an update following its adventures last Wednesday!
    • What are you thinking makes a sequential shit to drive on the street? About the ONLY thing I can think of, is if you're wanting to be able to roll up to lights in third or second and pop it straight into neutral, or you want to come down two or three gears, say out of 5th and back to second, but they shift quick enough it doesn't really matter
    • I'm not a drag racing guy, but that was a good watch. Didn't Ibrahim's car have some cooch! But the big question is....WTF is with so many of them running without seatbelts!
    • Sequential Is fine to drive on the street
