Mugabetown - Whoretownin' At It's Worst.
Are imaginary shirts off man hugs better or worse than real shirts off man hugs?
nothing better than skin to skin contact Mel. You should know this.
So shirts off man hugs got me thinking...............................and I would like to see more shirts off women hugs
  • Like 1
I think Mel and Connie should shirts off woman hugs.
The we will wear dresses... There is no shirts involved with that...
But I am not a man so therefore I don't know what man to man shirts off man hugs are like... Could be awkward...
hey if men do it I don't see why the women should be left out.
I'm all for equality
  • Like 1
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
