Mugabetown - Whoretownin' At It's Worst.
I will also be heading down, provided I don't blow up my car. Otherwise I'll have to get in on this plan B...
If you blow your car up, plan B wouldn't appeal to you.
Is plan B go to Canadia?
Yes, yes it is. Since dates haven't been posted last week when they were supposed to i suggest booking flights right now :whoops:
