Mugabetown - Whoretownin' At It's Worst.
Afternoon sir. Does that mean that motor and turbos and everything will be sold in order to start afresh? Few vultures may already be circling around that block.
Yes, most likely.
I was thinking of keeping it but I'm thinking that the next build will most likely be stroker
Yes, most likely.
I wonder who will pick up that motor. 2.8 stroker or 26/30 Ants? Choices choices choices.
I like 2.8 sound of things but everything is trending to 3ltr+ now which I personally makes things more complicated than what it really should be.
But I will once again do my homework first and then take it from there.
The big block boys have been saying it for years "there's no replacement for displacement". The cost of building a 26/30 would be punitive compared to a RB28 I would have thought? Or you could just go a Rb34 ;)
BTW I purchased a bottle of Laprhoaigh last week (the select cask)
That shit is so peaty that you want to punch your grandma in the face!
F me!
That stuff is nice! Although you aren't a peat fan from memory. It's ok, I don't think he takes it personally. :P
Yes, can't beat cubes hence Nick lol
Yes, I actually wouldnt mind getting another bottle which is called the quarter cask - 48% abv and has some really good reviews but yeah Peat and I don't get along as well as Sherry does.
Quarter cask is one of my brothers favourite drops. I too quite enjoy it. For your palate, I do recommend the Dalmore range or the Aberlour. Good stuff! Had Dalmore 12 earlier tonight and enjoyed it.
the QTR cask has scored 96 points. But yeah for me I like sweeter whiskys. Doesn't mean I don't like peated malts though
The Dalmore 12 is insanely sweet.
The Macs and Dronachs are one of my favs
But I like all kinds of whiskies
Yes, it's about tastes and also the mood you're in. Having said that I'm always keen to explore and expand my knowledge by trying other whiskies.
The Dalmore cigar malt is nice and the 18 I must try one one day.
Arberlour is on my to do list.
Right now though on the hunt for some Japanese malts :)
Japanese hey? Very pure crisp flavours. Which in particular?
any mate.
I've recently purchased Nikka from the barrel and that is just unreal
The best nose of a blend I've ever had and tastes magnificent.
Last night I had (a whee bit too much) Laphroaigh Select cask but that's because I really enjoyed that smokey aftertaste
Think I'm going to buy that QTR cask now, as I think I'm hooked on it now lol
The more refinement that goes into these peaty and smokey whiskies the less it tastes like an ashtray. The Ardbeg Perpetuum for example, nice heavy notes of tar and soot on the nose yet dark chocolate and honey on the palate. When you take a sip, has a nice warmth to it followed by smoke.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
