Mugabetown - Whoretownin' At It's Worst.
There's a really nice stealth black R32 in engine bay picks section with powerglide. Have been weighing up options and this approach for something for quick street/drag. Wet clutch, torque multiplication and transbrake for drag would make for a very interesting launch, if the theory meets the real world. Fingers crossed :)
there was a 500kw 32 in town that had a 2 speed in it, but i never got to go in it. had about a 5500rpm stall on it
then again getting hi powered rwd off the line cleanly is all in the launch control/suspension setup and how much rubber you can stick under it
lol look at the advice google gives you on that
also #@Beelzebub89 one for you, go into google on any computer and type in do a barrel roll and press enter.... watch google chuck a fit hahahah
So true. Set up will be drag orientated, but engineered. I get a pretty good supply of used Michelin race slicks from Porsche Cup car. They aren't totally gone, approximately 50%, but won't be using these on street - they are atrocious cold and HWP don't tend to see the positive traction side lol
What do you mean? Hwp love seeing racing slicks on imports on the street. They love that sort of behaviour. :P
On that note, morning all!
Cost/gain analysis - $50 each and no drag bags slapping into arches/guards and better grip than semis
They will have worse grip than streets let down to 20psi. Been there done that, it doesn't work.
On 18" qualifying tyres? This hasn't been my experience.
Yep. They have no side wall and no bag and most of them have seen too many heat cycles too. Good for circuit terribly shite for drag racing. A good set of drag radials picked up .5 of a second in the 60ft. 2 seconds down to 1.5.
The lesson I learned from all this is to use a tyre for what it is built for. If you aren't you are pushing shit up hill.
What a lovely day, and tomorrow is Friday :D
Tis a nice day. I am outside for half of it too. I do have to audit a fish processing plant though. .. bit worried about that, walking past the fish section at coles makes me gag
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
