If being on Internet forums has taught me anything, it's that emoticons/smilies can go a long way to indicating the intent of a post. If you're joking around and you're not 100% sure everyone else reading it will get it, throw in a smiley for reinforcement. Just make sure it's a clear one - thumbs-up and thumbs-downs in particular can come across as sarcastic.
I try to adopt a policy of approaching a new forum as if I'm starting a new job - you're polite and respectful when you first join, after a while you can slip in the odd witticism, and before you know it you're one of the crowd, where everyone understands your sense of humour and can tell when you're just having a bad day. I also do my best to avoid sledging, because one day I just might meet the guy I've enraged in real life and I'll discover he's 6ft 9in tall, made out of granite and finds me irresistably sexually attractive.
:P <-- Required smiley...
What he said, as a cynical ar5ehole in real life my opinion often needs to stay on the inside, I try to treat forums the same way.
Its difficult enough to interpret sarcasm from people you have just met with out a text only format getting in the way.
That being said, I like this part of the forum as it seems to stay on topic most of the time and fun poking between mates is fairly obvious.
I know i can find information here and if I cant someone will point me to it.
I guess like minds are attracted to similar toys.
As my wife has pointed out at cruises the guys I meet are just variations on me and my personality....
Dont know if anyone else has noticed that. :no:
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
