Hi,
I'm chasing a short stub axle to suit R33 Gtst R200 diff. Changed the Viscous centre over to an ATS 1.5 way today and discovered, like the Nismo, it requires two of the shorter stub axles and I only have one.
Will by a pair if someone has them and doesn't want to separate.
Let me know if you have one/a pair and how much you want for them!
Cheers
Jamie
https://www.sau.com.au/forums/topic/431503-wtb-r200-5-bolt-stub-axles/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
