For Sale: [NSW/SYDNEY] 2003 Mitsubishi Evo 8
Colour: White
Mileage: 101,000km, 2,000km on the new setup (engine, drivetrain, turbo setup)
Selling as I'm looking at buying a house and a get around Honda S2000.
Makes 469.4kw tuned by Vince at V&E Rigoli on a safe and reliable circuit tune. If you want more power simply increase the boost or timing for a drag/street setup and it will easily sing over 500kw at all four wheels.
Car’s PB is a 1.03.9 at Wakefield Park on a run in tune at 280kw
For all mods listed with the extras, I am looking at $45,000. This is negotiable as not all extras are wanted such as the extra set of rims and new sets of tyres.
NO TIME WASTERS. NO JOY RIDES unless a deposit is taken.
Modification List:
Engine/Power Mods:
• Trust Ti-R titanium catback exhaust
• Precision 6262 4” SP housing, dual ball bearing, v band rear housing
• High Pressure Oil feed line kit with filter
• Sparktech Ignitions CDI COP kit
• Spartech quick disconnect
• Sparktech billet coil protectors
• M&W ignition amplifier
• AMS/Moroso baffled sump
• JMF small battery billet holder
• Odyssey PC925 Dry cell battery
• MAP 3” dump and front pipe
• MAP top mount 1.5” runner top mount manifold
• MAP 4” intake pipe
• K&N 4” pod filter
• MAP external gate
• MAP hotside intercooler pipe
• GSC S3 280 camshafts
• Custom V&E Rigoli cold side and upper intercooler piping
• Turbosmart 45mm Compgate external wastegate
• Turbosmart 50mm Raceport
• Turbosmart silicon vacuum hoses
• Turbosmart Eboost2
• Earthing Kit
• Speed density
• H11 headstuds
• ETS 4” front mount intercooler
• GCG copper exhaust manifold nuts
• Turbosmart Murray Tension Clamps
• Greddy Oil temp/pressure sandwich plate
• Supertech dual Valve springs and retainers
• Supertech valve stem seals
• Supertech 1mm black nitride oversized exhaust valves
• Supertech 1mm black intake oversized exhaust valves
• Supertech oversides valve guides
• Reconditioned head
• Supertech valve guides
• CNC ported valve throats
• Head and block decked
• OEM Mitsubishi evo 9 headgasket
• Machined and tunnel bored
• OEM Mitsubishi lifters
• S90 Billet 70mm Throttle Body
• Garage HRS Dip stick holder
• Custom Test pipe
• ACL bearings + King Thrust
• ARP Main Studs
• Wiseco Pistons 1400HD 20thou over
• Howards Billet I-beam Rods
• OEM Gasket Kit
• balance shaft delete kit new OEM bearings
• Gates Racing Kevlar Timing Belt kit
• Brand new OEM Mitsubishi EVO 8 water pump
• Brand new OEM Mitsubishi evo 8 starter motor
• Kiggly HLA
• MAP Rev3 intake manifold ceramic coated
• JMF radiator overflow bottle
• KOYO alloy radiator
• Titanium engine bay bolts
• Torque Solutions solid billet engine mount
• Torque Solutions solid billet 5 speed gearbox mount
• Torque Solutions solid billet front engine roll stopper
• MAP Setrab oil cooler kit with braided lines
• Zaklee Clear cam cover
Drivetrain:
• Torque Solution Shifter bushing
• Torque solution Shifter base bushing
• Torque Solution Drive shaft carrier bushing
• Evo 7, 5 speed gearbox. (PPG straight cut 4.11 FD, strengthened bearing by Rigoli, Jacks transmission new synchros and sliders etc, assembled and reconditioned by Rigoli
• Evo 7 5 speed conversion kit
• Upgraded MAP transfer case ring and pinion
• Upgraded transfer case bearing
• Brand new OEM Mitsubishi O ring seal kit for Transfer case
• Wavetrac LSD
• AMS gearknob
• Exedy triple plate clutch
• Exedy lightened flywheel
• MAP billet clutch fork stopper
• ACT Monoloc
Fuel Setup:
• Walbro 255L fuel pump in-tank
• Works billet fuel rail
• FIC 2150cc Injectors, PNP adaptors
• 2 x Aeroflow 044 external pumps
• V&E Rigoli custom surge tank
• EARLS billet fuel fittings
• EARLS braided fuel lines
• Turbosmart FPR1200
• Turbosmart FPR gauge
Interior:
• Defi gauges
• Full Evo 9 leather interior (door trims, front and rear seats)
• Evo 9 Ralliart carbon fiber interior trims
• AEM A/F wideband gauge
• Pioneer speakers
• Headunit
Exterior:
• Carbon ralliart style front lip
• APR GTC300 67”carbon wing
• APR 67” carbon gurney flap
• Evo 9 rear bar
• Genuine OEM Mitsubishi Ralliart Vortex Generator
• Genuine OEM Mitsubishi Window Visors
• 10% window tint
• Evo 8 MR Canards
• AME TM02 Tracers 18x9.5 +22
• 95% (pretty much brand new) Yokohama Advan AD08s 265/35/18
• Stock evo 8 rims (brand new Bridgestone RE002 235/45/18) – spare set of rims
• Rear guards rolled by Phil B Enterprises
• Brand new set of Hankook Z221 Mediums semi slicks 265/35/18
Brakes:
• Braided Brake Lines front and rear
• Performance Friction 2 piece dimpled rotors fronts
• HAWK DTC 70 front brake pads
• DBA4000 slotted rear brake rotors
• Girodisc Magic Pads rears
• Castrol Super DOT 4
Suspension:
• Summit 4 point boot brace
• Tein Monoflex coilovers with Ohlins and Swift Springs 16kg R and 14kg F (Custom Valving)
• Whiteline 26mm front swaybar
• Whiteline 24mm 3 way adjustable sway bar
• Ralliart –Solid Bushing rear diff support arm (2)
• Ralliart – Solid Rear diff member bushes (2)
• Hardrace front lower arm bushing set
• Hardrace front centre roll adjuster 15mm
• Hardrace rear trailing arm bushing
• Hardrace rear adjustable toe arms
• Agency Power billet rear adjustable camber arms
• Evo 10 adjustable camber bolts
Price: $45,000 NEG
Contact Details: PM or 0424 519 217
Photos:
1238324_10151580135296875_219037437_n.jp
1231685_10151580135161875_1569097145_n.j
1174689_10151580135301875_713828376_n.jp
1176379_10151580135206875_907407353_n.jp
1240283_10151580135231875_1658151829_n.j
999860_10151580135306875_1260559224_n.jp
https://www.sau.com.au/forums/topic/431800-for-sale-nsw-mitsubishi-evo-8-470kw/
  • 4 weeks later...
  • 1 month later...
Hi, guys
That EVo 8 has some serious power, what boost, My mate Jim took his EVO 9 with stock internals ( 265kwat ) and went below 1:45 at Phillip Island, wonder what lap time he can do with the one you have sold.
Trying to get a car to go to 2014 F1 Albert Park drive (club sprint style )S15, GTR33 or EVO
happy motoring
Alex
    • How dare you sell your unreliable Skyline and buy a reliable, Toyota/Yamaha car with a strong gearbox, torsen LSD and Toyota reliability. At least you won't need to worry about oil pumps, big catch can, oil restrictors, blowing off power steering belts, sheering off 3rd gear, failing ABS relays/pumps, etc.
