My car is a 1.5, engine has bits from S1 and S2 but more S2..
No problems so far and i think fuel economy has remained the same.
Didn't want to hear that last bit T^T
Filled up again, 10L per 100km but was $1.71 today.
Well considering my latest fuel economy was 13.99L/100kms and that was $1.69 when i filled it up, in saying so there was a mountain run involved in that tank of fuel. pulled 356kms out of 49.71L that was on V-Powah
I'll drive this tank really low and see my fuel economy on P100 but I'll fill up with v power and see if my economy gets worse or stays the same.
At the moment I'm not sure if it's the fuel or the brand new CAS that I installed 2 weeks before I started using this different fuel.
True, I'm half wondering if my new high flow cat is causeing the jump in fuel useage.
Btw this P100 fuel has up to 10% Ethanol added not 5%.
I'm keen to install my PowerFC again, will be a good way to monitor knock BUT saying that I haven't felt the standard ECU reduce power entering the knock maps....
Just do it Zeke. The poor old Ark is on deaths door but even she runs well on it.
P100 = No engine light, better economy, not running rough
Shell or BP= carries on like the ark
  • 4 weeks later...
Car had P100 for happy laps and is going great :D
Did 13L per 100 km from home to happy laps and back.
If I had the money I would get the car tuned on this fuel with the PFC I have sitting around.
13L:100kms :( better then mine. But you've heard what's going on my end with fuel. I'm getting just under 14L:100kms
I've run P100 in my R34 for about 6 months and had it tuned on it, power went up from 200rwkw to 217.8, not a bad increase seeing as nothing else changed. I generally get between 500-550kms on a tank but that's almost all highway driving. Definitely gives the car more power down low I've noticed too, never going back to 98
Should be perfectly fine, but a good precaution is to change the fuel filter after the first or 2nd tank. This is because ethanol can dissolve some of the gunk built up in the system.
The extra fuel usage would only be 2-3% on closed loop, and essentially nothing on open loop unless you re-tune it slightly. The ethanol content should help in hot weather as a bit of ethanol both boosts octane and broadens the optimum optimum timing point.
I wonder if it is only 100 octane, or 101-102 ?
There's reason to believe that it can fluctuate because of how the ethanol reacts. Could be higher, could be lower. From memory, I think that it's a minimum of 100 octane.
Also, you mum. Hehehehe (reference to your signature)
Never tested it, would be interesting to see. The performance difference is considerable, I went back to 98 this week and the car feels like crap.
This would equate to the ethanol burning more efficiently and assisting with the combustion of the petrol. Whilst it's small in what it does, with a car like yours, the change in feel would be remarkable however the actual numbers wouldn't change to much. Also, ethanol would assist with better, cleaner det - important especially on yours.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
