Originally posted by Nizman
 yeah, but an exceptional one:D Is that Gavin Wood at Labrador? I've heard just recently he's the man for skyline servicing in SE Queensland.
$1500 bucks for all the parts:rolleyes: from what I could find that's enough to cover the box only!!!
Yeah. We've been to him 3 times now. All for different problems. One being the HICAS. Its fixed now but something else is wrong (which wasn't his fault) and we've had it serviced by him too. Can't complain about anything. Cept the Boost gauge we got put in stopped working but thats only cause the line crimped behind the face of the gauge.
He's not too expensive either.
[/plug]
https://www.sau.com.au/forums/topic/432-qld-members/page/6/#findComment-24012
  • Replies 250
[/plug]
https://www.sau.com.au/forums/topic/432-qld-members/page/6/#findComment-24013
Well I'm Gary,
Most of you will remember as Gary from the old SDU forums. I have since sold my 33 gtst.....(sob sob) and am soon expecting my new 260 RS Stagea, and boy am I looking forward to that day... I live on the Western side of Brisbane and enjoy going for "spirited" drives through the mountains... Now that the new forums are up and running I will speak to you guys more often. I guess I will see you all later at some time.
Cheers
Gary
https://www.sau.com.au/forums/topic/432-qld-members/page/6/#findComment-24756
Just an update, for anyone who cares... I finally got my dirty little hands on an R33 GTS25t over the weekend. It's sitting in Osaka at the moment, but should be in Bris on the 5th of August and in my dirty little hands about two weeks after that.
Originally posted by Sciby
Name: Scott, but literally everyone calls me Sciby, including my 2 year old godson and before you ask, it's pronounced "Sky-bee".
Car: Don't ask what I drive now, but just had a loan approved, so I'm about to hunt down an R33.
Occupation: Sysadmin (professional geek) at the same place as Squizz.
No doubt will meet some/all of you when I finally get the new car.
https://www.sau.com.au/forums/topic/432-qld-members/page/6/#findComment-25004
Originally posted by jay51
I'm Jay  age 61   retired Rn.   non retired revhead and PC freek
 Hi Sciby.... you still with OCAU?
Hey Jay,
Yup, still doing the OCAU thing, but I haven't done news posts for ages. Typing all that out gets very boring after a while. I mainly write articles now, but I still administrate the forums and irc channel as well.
Was rather surprised to be recognised on here via OCAU. :(
https://www.sau.com.au/forums/topic/432-qld-members/page/6/#findComment-25009
Well the car has to be complied as standard.....(bugger)...
Mine is to get upgraded turbo's, new computer, exhaust, 18 (maybe 19) inch wheels, and dropped on it's guts. I'm also thinking of stroking the RB26 up to a 3 litre:D Then it should produce around 500 horses at all wheels. I'm also doing a bit of a body modification, but I'm keeping that secret at the moment.
What I want is, evryone to think WTF!!!
Be patient and all will see the unleashed beast.
Cheers
Gary
https://www.sau.com.au/forums/topic/432-qld-members/page/6/#findComment-25065
As much as I'd love a 34 GTR, there's just something about a super fast WAGON that I can totally dig. Imagine some wanker in his V8 Ute thinking he's king of the world, next thing this big arse wagon with huge wheels pulls up next to it and looks over. Then bang, what ute ?
I'm sure that's what you're thinking aren't you gary :uh-huh:
https://www.sau.com.au/forums/topic/432-qld-members/page/6/#findComment-25078
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
