So thinking of getting an Apexi power fc with the controller for my 33 to replace the stock ecu. Would the AFM need replacing? Also does anyone know what pricing I would looking at for one? And wlany suggestions where to purchase it from etc? Any other information I need to know to do this would also be helpful just trying to plan ahead so I know what im getting myself into.
Thanks in advance.
https://www.sau.com.au/forums/topic/432202-apexi-power-fc/
You need AFM's with the power FC. Unless you get the D-Jetro version which takes out the AFM's. thats what I'm lead to believe
Ok so what you'd use stock AFM or swap for a Z32 AFM?
https://www.sau.com.au/forums/topic/432202-apexi-power-fc/#findComment-7031375
I've written it somewhere else before, but I'm not a big fan of Nistune. If your very price orientated then I guess they are a good option. I think I stand alone ecu is the best way to go. Power FC, vipec/link or haltech..
https://www.sau.com.au/forums/topic/432202-apexi-power-fc/#findComment-7031407
Either better then the other or all bout the same just different badge? This is something im contemplating doing late next year so just collect as much info as possibke now to decide what way im going.
https://www.sau.com.au/forums/topic/432202-apexi-power-fc/#findComment-7031414
it all really depends on exactly what you will want from it. future mods, tuning adjustment, how much you want to spend, etc..
They are all different and better in their own ways.
It's all been covered in various treads, so i suggest starting with spending hours reading through them as most people won't want to repeat themselves again and again and again. Recently I have read about some nistunes not working for unknown reasons also some PFC having problems with the not so old models, as compared to the old ones, lol..
But basically you first need to know what you want in the end, then find the appropriate steps to get there. Or at least an idea of what you want from each piece as you source it..
  • Like 2
https://www.sau.com.au/forums/topic/432202-apexi-power-fc/#findComment-7031430
I actually think a power FC offers very little over a Nistune, its really only the hand controller and the nistune actually offers more load points. The Nistune has the added bonus of being cheaper. In a mild build my choice would be nistune, beyond that I would go Wolf, Link, Vipec ect. The power FCs time has come and gone IMO
The stock RB25 AFM will handle up to about 250rwkw worth of airflow. I wouldn't worry about changing AFMs unless you are shooting for something above that.
https://www.sau.com.au/forums/topic/432202-apexi-power-fc/#findComment-7031496
This is the most cruicial part in a build.
https://www.sau.com.au/forums/topic/432202-apexi-power-fc/#findComment-7031519
Over the next 5yrs I want to avoid having to do any internal work. Now that my mates got a 350+ supra I've got some catching up to do. But at the end I can say I did it and not just bought a car already at that point after someone elses work.
https://www.sau.com.au/forums/topic/432202-apexi-power-fc/#findComment-7031530
If you want to get the best out of the car without pushing the envelope too much go Nistune, z32 AFM, 550cc injectors and a R34 High flow turbo. Enjoy a trouble free 270 to 300rwkw.
That would probably be more than enough to serve it up to an uber boat supra
https://www.sau.com.au/forums/topic/432202-apexi-power-fc/#findComment-7031549
Learn from my mistakes, Buy a Vipec as it is best suited and will support things like AFM's less tune (has a 3 bar map sensor built in) flex fuel tune (sensor can be brought for it) and nearly everyone can tune it.
https://www.sau.com.au/forums/topic/432202-apexi-power-fc/#findComment-7031936
I agree with Clint, but that may be biased due to me having a Vipec. I Believe Andy (Bunta) also recently made the change over to a Link/Vipec ecu, think he had a Haltech previously from memory
https://www.sau.com.au/forums/topic/432202-apexi-power-fc/#findComment-7032037
I had a power FC. Link/Vipec are good as are Adaptronic, Wolf and to a lesser extent (in my experience only) Haltech. But if budget is a consideration Nistune is the answer if you dont need external inputs like crank triggers and boost controllers ect ect
https://www.sau.com.au/forums/topic/432202-apexi-power-fc/#findComment-7032117
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
