Hey Guys ,
So i am faced with that decision to let my r33 gtr 99% finished project go. a bit about it:
Bcnr33 5/1997 build r33 gtr
Body: Stock apart from resprayed engine bay. Normal Gtr Headlights as xenons which it should have had factory were not with the car. series 1 / 2 front spoiler lip (i have the shittest driveway..)
Engine: Early Rb26 block from 89 r32 gtr (was virgin block) had block dipped and tested and machined. r34 gtr crankshaft polished checked and balanced. acl race series engine bearings were used. nismo oil pump was fitted. tomei conrods were used with je forged pistons. tomei baffle fitted to sump. tomei oil restricter fitted to block.fitted arp head studs and acl race head gasket. cylinder head cleaned tested and faced. fitted and clearanced tomei type b poncams. fitted new guides recut valve seats . has vernier inlet and exhaust cam gears. genuine std nissan water pump fitted. gates racing timing belt kit fitted. engine timed cams dialled in. fitted intake manifold, covers etc. new id1000 injectors fitted with adapters. fit push type gearbox. fit orc twin plate clutch. fit engine to vehicle. fit new alloy radiator, fite new belts, fit external oil cooler and lines. has trust greddy twin high mount td05 kit ( both turbos reconditioned) , trust manifold and external gate. aftermarket trust intercooler suit turbo kit. high flow cat and hks 3 1/2 inch exhaust. greddy oil catcher can.
Engine Management: Tomei Reytec Rb Fully Programmable ecu and english software and tuning cable.haltech wideband controller
Fuel system: id1000 cc injectors (e85 compatible) and walbro intank 420lph e85 fuel pump.
Suspension: tein coil overs
Brakes: Front Brembos Upgraded to 350mm Brembo Kit Rears Standard r33 gtr brembos nismo brake hose kit
Wheels: Rota Torque - (cr Kai copies) kumho 265 35 r 18 tyres
Sound System : mp3 head unit alpine splits in the rear and jl splits in the front.
Full Security system with auto window closer and other extras ;-)
blitz fatt turbo timer
car had genuine 86, 956km on it when i got it, since motor build it now has 87770km . it is still on a run in tune and is still running in. boost is down at 13 psi.
So... What It needs to be completely fininshed, boot trim carpet (piece that covers battery area) fluids changed (at around 1000km) and a dynotune. and repair crack in front lower lip.
i am very sure the car has alot of potential. i am unsure potential buyer would be extremely happy with it as i have put 110% into it. i am not a back yard mechanic i am an auto electrician & mechanic by trades. have a pile of reciepts for much of the parts put into the car. i have simply run out of time, (work related, family etc) and never get the time to drive & enjoy the car .
Soo what im looking at chasing for it (alot less than it owes me , but thats cars eh,) is $25,000 ono. with rwc and remainder of reggo. i am not in no rush to sell it, so please no low ballers. please only genuine buyers contact me as no one like wasting time. am looking at the likes of getting a bigger family car (Nissan Patrol) so unless you have something along the lines of that no offers to swap please. no test pilots , there will be no test driving unless you hand over i.d and deposit.post-84496-0-01494300-1380190289_thumb.jpgpost-84496-0-07934900-1380188478_thumb.jpgpost-84496-0-38252000-1380188483_thumb.jpgpost-84496-0-25818700-1380188487_thumb.jpgpost-84496-0-91720600-1380188495_thumb.jpgpost-84496-0-37606100-1380188499_thumb.jpgpost-84496-0-91690000-1380188502_thumb.jpgpost-84496-0-54739000-1380190173_thumb.jpgpost-84496-0-35856700-1380190209_thumb.jpgpost-84496-0-91148600-1380190246_thumb.jpgpost-84496-0-53758400-1380190277_thumb.jpgpost-84496-0-66025300-1380190280_thumb.jpgpost-84496-0-45450100-1380190282_thumb.jpgpost-84496-0-66721700-1380190284_thumb.jpgpost-84496-0-86401700-1380190286_thumb.jpg think i have covered most of it. any questions just ask, or pm me. thanks
https://www.sau.com.au/forums/topic/432379-r33-gtr-eoi-possible-trade-for-sale/
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
