Desperately needed GTR parts...
You are selling this? I have never bought something from marketplace...i dont know if i trust that enough. And the price is little bit "too" good...
By Watermouse · Posted
https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr -
By BuiltNotBought · Posted
There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
