Pains me to do this but I must let go of my street wheels. Need the extra dollars as we have a baby on the way and plus these sit at home untouched as I always run my track wheels.
19 x 9.5 +12 (265/35/19 Pirelli Corsa)
19 x 10.5 +12 (305/30/19 Nitto Invo 500km old)
These are super aggressive and clears big brakes. Super light forged wheels in rare discontinued Diamond Black
Will throw in a set of brand new Rays Lug nuts to suit (worth $180)
$4200 in sydney May swap for some 18" wheels
Here are some pics
And you can see here the tiny bit of rash the one wheel has (the rest are perfect)
Shane
https://www.sau.com.au/forums/topic/432396-19-te37-diamond-black/
Would you swap for 18" Stagea m35 axis autech rims with near New tyres plus cash your way? Pm me.
I need a better offset to fit a big brake kit.
Thanks
Justin
0411171616.
  • 1 month later...
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
