Selling my S13 NISSAN 180sx , BLACK TOP SR20DET ( THE CAR IS A NICE DEEP RED THE PICTURES ARE LOUSY AS IT WAS WITH MY PHONE AGAINST THE SUN AND THE COLOUR IS NOT LIGHT RED AT ALL LIKE IT APPEARS TO BE ON THE PHOTOS, ITS A NICE FACTORY DARK RED ORIGINAL PAINT) had a slight tap from the front, drives and runs well, rego run out didnt get to fix it, easy fix, roadworthy and register back onto the road.
CLEAN AND HARD TO FIND 1995 late model Rare in Aus and still "virgin" / unmodified
160000kms
Everything electric from power windows/mirrors/steering etc
Auto SR20DET Turbo
100% stock standard from exhaust system to airbox, very very clean original and mechanically serviced
Interior in excellent condition
Uncracked dash , like new
Interior extremely clean ,perfect condition
Aftermarket steering wheel and boss kit
Original late model 180sx wheels with good tread bridgestone tyres
paint is in fairly good condition some blemishes here and there
runs well with icy cold aircon
Great car for a stock legal daily driver or suit P plater with exemption good stock base for a track car too etc
Located in Southside Brisbane
please ring or text me on (Contact Seller) for an inspection.
WILL SELL SHELL AND MOTOR PACKAGE SEPARATELY .
  • 1 month later...
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
    • Ahh. Well the block damage is a problem, you really need to run a tap or thread chaser through it to see if the threads can be saved, but any chips are likely to be bottom end bound which is bad. Earls seem to have what you need if you want to stick with mounting direct on the block: https://rceperformance.com.au/parts/earls-straight-adapter-1-8-npt-male-to-1-8-bspt-female.html, but as I said above I'd recommend remote mounting the sender
    • I'm not quite understanding or I'm missing steps here, (I appreciate people are trying to inform my brain but I am of the dumb, especially today) - All I want to do is mount the male BSPT of the OEM sender into the system somewhere without it snapping the adapter via vibration. The Nissan sender has a male 1/8 BSPT output. The block has a (very destroyed) 1/8 NPT input. I'm not really sure how a lathe assists with that, and also don't know anybody with a lathe, nor specifically what I would want to buy. I'm not really sure how adding additional adapters creates a better, more leak proof resilient seal here.
