Morning gurus,
I bought a skyline 12 months ago and the owner said he changed the turbo, I can't remember whether he said it was a 3071 or 3076. How do I tell the difference? It's internally gated if that helps (although I believe either can be internally gated?). I thinks it says 0.67 a/r on the turbo itself.
Any help would be great. Cheers
https://www.sau.com.au/forums/topic/432603-gt3071-or-gt3076/
there should be a little metal plate with numbers n letters stamped on the core (around where the hoses go in and out of the centre of it).
take a photo of that plate and either take that to a turbo specialist or maybe even someone on here can help you to sus it out based on that. n yes, you'll also need to get the A/R ratio numbers stamped on the housings.
Most "real" GT3076Rs have an anti-surge housing - if it sounds like a jet spooling, its a 56-trim GT3076R with the anti-surge housing. If it doesn't, doesn't mean it's not from the range of "GT3076R" titled things... but it's much more likely to be a GT3071R.
Hmmm not sure, it does scream when spooling but it's my first turbo car so can't really compare.
An original Garrett GT3071R will have 0.50 AR on the compressor housing , the real GT3076Rs have 0.60 AR compressor housings .
A .
Must be a 3076 then because I definitely remember 0.6x a/r on the comp housing
So, say it was a 3076 what is a safe level of boost to run at constantly? I've been told all I need is a stiffer waste gate spring and I can run 21psi, would that be too much for the turbo to handle long term?
I don't see why not, how much boost are you on now? also maybe talk to a tuner before you go raising boost too much
It's tuned for 7, 10 and 14 PSI currently, I won't be changing any boost pressures with out a tune. Just wondering if a 3076 could handle 21PSI day in day out or if it would need to be turned up to 21 sparingly
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
