hay guys i have a problem and for the life of me cant find the cause
car is a s1 r33 one morning i came out and started the car started fine as u usual was sitting there idling getting ready to go and it just stalled would turn over but not fire. Traced the cause of that back to the coil packs i have lost my 12v to the coilpacks, for the time being i have tapped into the 12v on the side of the engine bay and it starts perfect(will this hurt anything by the way?) but cant seem to find out why the 12v in the loom has gone. Is there a fuse for that specific 12v to the loom or could it be something else ?? any help would be much appreciated cheers guys.
https://www.sau.com.au/forums/topic/432635-r33-12v-to-coilpacks-is-gone/
sorry should have added this before the loom on my car has been changed to a s2 loom and coils and as i said the car was running fine before so i know its not the wiring on that thats the cause ??
Try looking at fuse number 3. It feeds an ignition relay above the ECU that pulls in when the ignition is turned on and sends the 12V to the coil packs.
There are a few 12V relays just above the ecu in the passenger kick panel. Can't remember if its the blue or brown one. You should here them click when you turn the ign on
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
