Harro,
Just stuff lying around the garage, all parts are used.
Factory Steering Rack Ends/Tie Rods $10
Factory Steering Tie Rod Ends $10
Factory SMIC $50
Factory SMIC piping $50
Factory Cross over pipe & BOV $50
Factory Down pipe $20
Factory Dump pipe $20
Factory Catalytic Converter $50
Factory O2 sensor $10
Factory Mint Handbrake OEM boot $10
Factory HICAS unit $20
Factory Passenger side kick panel, 1x flare clip broken $5
Factory Stock R33 Rims x4 (tyres might not pass an inspection) $100
Bendix DB1170 Front Brake Pads (Near New) - "Guaranteed Race Car Like Squeal" $30
Blitz 60mm Gauge Holder $5
Subframe Lock Collars - Blue in Colour, full set (8 pieces) $40
Contacts: PM or Reply Here
Location: Canley Vale, NSW, 2166 (AH) OR Milsons Point, NSW, 2061 (BH)
Will post some items, but prefer pick-up. Will give discount on bulk purchases, and yes I accept beer as payment also (no VB, Fosters, XXXX, etc..)
Would you post to sa? If so how much would you want for them sent?
yeah and $20 ontop would cover it
Schizzle for sale... help me fund mah modz :)
Factory SMIC $50
Factory R33 GTS-t Manual Radiator, working removed for upgrade $40
yezzzzz
Sold:
Available:
Factory SMIC $50
Sold:
Available:
Factory SMIC $50
Sold:
Available:
Factory SMIC $50
Friday bump this schizzle...
You know I'm negotiable right? How about give me 3x slabs of Blonde and you can take everything remaining in this thread.
Sold:
Available:
Factory SMIC $50
Some updates, tyres fell through.
Take everything available here for $150 or 3x slabs of Blonde.
Sold:
Available:
Factory SMIC $50
Factory HICAS unit $10
Factory Stock R33 Rims x4 (tyres might not pass an inspection) $80
Bendix DB1170 Front Brake Pads (Near New) - "Guaranteed Race Car Like Squeal" $20
Fully Sick Gearboot & Handbrake Boot in black leather with purple Stitching $10
Sold:
Binned:
Available:
Factory SMIC $50
Hey bud
I'm interested in the dump pipe, down pipe and the bov (if you're willing to seperate it)
Though i'd need it posted to vic.
I'll pm anyways
  • 3 weeks later...
Sold:
Binned:
Available:
Factory SMIC $50
  • 1 month later...
Available:
Factory SMIC $50
Superlow Rear Springs R32/R33/R34 GTS-t/GT-t $40
Sold:
Binned:
Available:
Factory SMIC $50
Factory Blow Off Valve $30
Factory R33 GTS-t Manual Radiator, working removed for upgrade $20
Sold:
Factory Cross over pipe $30
Binned:
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
