Car is an r34 4 door GT.
Was factory auto n/a now converted to manual using an rb25det neo box and running a turbo viscous LSD and not the factory open centre with sensor on the side.
Everything is sweet and it's been my daily for the last 4 months. However my speedo is only reading half as it's not connected at the speedo sensor on the box. The speedo sensor just has 2 light green wires coming from it that has been cut and it just dangling. How do I go about hooking this up ? Anyone have a Pinout for this speedo sensor ?
The car is still running the n/a engine and box loom so there is a lot of cut wires under there by the box.
Car is also still running the auto ecu.
Any feedback would be greatly appreciated.
https://www.sau.com.au/forums/topic/433304-r34-manual-conversion-speedo-issues/
I didn't do the manual conversion on this car. But the sensor in the diff at the back on the cog for shaft, if I unplug that, my ABS light comes on an my speedo goes dead. Plug it back in and my ABS works again and my speedo reads half ?
As for the speedo sensor in the box, it's not wired in, it's just 2 bare green wires hanging down.
Given that that doesn't make sense, you can see why I'd ask.
Did the original auto box have a speed sensor that was wired up to the undercar loom?
Have you considered wiring up the speed sensor on the manual tranny to the original undercar loom?
I will point out that I don't know about the R34s autos in particular......but on an R33 manual gearbox there is just two wires from the speed sensor. These give a 0-5v square pulse that is wired direct to the speedo head. The speedo head translates that to a sawtooth (AC signal) at a lower voltage that is sent to the ECU and any other controllers that need speed signal, like HICAS, ABS etc. The speedo sensor on the R34 manual should be the same. BUT....the fact that you also have a speed sensor on the diff, that is somehow giving you a 50% pulse rate to the speedo head is a very strange thing. I'm not sure how they would have wired that up to work if it also needs a gearbox sensor. Just too strange.
On the topic of the auto ECU....how the hell can this be true? The Neo turbo ECU (if auto) has the TCU built into the ECU. The Neo NA ECUs do not, they rely on a separate TCU. You cannot run the Neo turbo engine off the NA ECU. So, if what you are saying is that you have the engine running off a proper Neo turbo ECU and you still also have the old auto TCU box in the car, then it doesn't matter. That old TCU will not be doing anything. The ECU will ignore anything the TCU tries to tell it and the TCU is not hooked up to anything it can influence (except maybe ABS or traction control perhaps).
  • Like 1
The car is non turbo with a DET neo manual box, still running the factory n/a auto ecu.
And I don't know how the diff is giving me a half speedo reading. I don't know anything about the auto setup as it was converted before I got the car.
So I'm wandering, what's the Pinout for the auto loom speed signal and can it be wired to the manual box speedo ?
I find it really difficult to believe that they had different clusters (different speedo heads) between auto and manual cars. Therefore it should take nothing more than hooking the two wires from your gearbox speed sender to the two wires from the cluster (speed signal input). How the hell the diff mounted sender gets involved is a whole 'nother question.
To find the correct wires you may have to get the cluster out and work out which wires go to the speedo (via tracing the circuit on the cluster). The 0-5v signal is polarised, so if you don't get it to work you may need to swap them.
And ..... aaaaah. I see about the ECU now. No turbo. Fair enough. In that case, there is nothing to worry about in that regard. The ECU receives a speed signal - it doesn't provide it to anything. It doesn't care what else you do with the gearbox, so long as it gets some sort of speed signal, which it is at the moment, even if it is strangely half what it should be.
From memory, last time I looked, there is about 6-10 bare wires under there coming from the loom.
Could I simply turn the ignition on and find 2 wires putting out the 5v signal and connect them ? Or will no signal be sent through due to it not being hooked up to the speedo ?
  • 7 years later...
Wow. Notified that someone reacted to my post above (the first one from Oct 16) and realised just now that I completely hamfisted the signals. The gearbox sender makes the +/-1v sawtooth (AC) signal and the speedo head in the dash converts that to 0-5v square wave PWM signal for the ECU.
I must have been on cough medicine that day.
  • 2 years later...
Sorry to revive this topic again Rb20det Gearboxes are caving my head in.
So I have Rb25det With a rb20det manny trans. In my C34 auto converted . the speedo Is reading half the speed and i dont know where to start
So what ive got is the speedo in the gearbox sends an electric signal to the dash which converts it and whats happening is its only getting half ? so do i need an electric converter. Rb25det electric speed sensors are long ones so they wouldnt work with my rb20det one
What sort of speed sensor was used in the C34 auto? An electronic sender like in the typical RB25DETmanua l box? Because, if so, you are shit out of luck. The RB20DET speedo is usually by cable drive. I don't know of any electronic drives for that gearbox. There are for the related 4 cylinder gearboxes in Silvias etc, but I don't know if they are useful.
So, where is this odd "half" speed signal coming from? If you can identify if it's coming from a diff sensor or ABS sensor (ie, that's the original way it was on the C34) then you might be able to just use a speedo adapter box like you can get from Jaycar and various auto-electrical crowds.
Manual non turbo r33 speedo drive should sort it, electronic drive for the 20 box
You know. I'm a bit dense. I should have thought of that! It's not as if I didn't fit an R34 NA box to my R32 at one point, and removed the electronic sender from it!
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
