Hi trying to help a mate hunt down a C34 RS4 S2. Needs something genuine, in clean overall order asap. Have exhausted all the regular sources. Carsales, bumtree etc. Wondering if anyone here knows of any vehicles tucked away in Brissie surrounds or Gold Coast.
Thanks.
Edited by D-limo
I have a immac C34 S2 auto in pearl white
Alot of quailty Jap extra's and electonic extra's, hiflow etc
Looks clean and stock on the outside
$8500 unreg and will provide RWC for rego
No issues with car
Car southside Brisbane as Capalaba
PM me if interested
Edited by darrinspencer
  • 4 weeks later...
After collectively browsing through at least 500 cars over the last couple of months mate is now a proud owner of a pearl White S2 :) Thanks Darrin for going out of your way to get the deal sorted. Pulled a healthy number on 999 automotives dyno at 11 psi (mention of a high flowed turbo was lost in translation somewhere along the line). They complemented the quality of mods made and after seeing it in the flesh I had to agree and was a bit jelly.
Going back on the rollers in a few weeks to pump some more boost in. Thinking around 18 psi if the fuel ump can handle it? If you have the turbo specs handy Darrin that would be awesome. Looking at ordering in a 'Blitz Advance Power' pod before then. Is anyone on here running a stainless mesh filter and/or a hard induction pipe and did it do much for induction noise?
Edited by D-limo
We bailed the pod idea as there now seems to be grey area regarding secured, non enclosed pods in QLD. Hard pipe was considered. Might be deemed worth while if there is a noticeable gain in response to be had.
Been told it's running a Sard fuel pump. I can't find solid info on standard S2 injector size. Can anyone confirm?
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
