Rb26dett engine from a r33 Gtr vspec, motor has done approximently 10,000kms since build. I have pictures of recent cold/dry compression test and can send or show to serious buyers only.
**Can fit and install for extra by mechanic locally on the Gold Coast pm for details**
Compression 160-165psi across the board
Bottom end
R33 Gtr crank
Genuine N1 block (24U)
20 Thou Cp pistons and rings
Eagle rods with arp rod bolts
Arp mains
Arp head studs
Greddy oil pump
N1 water pump
Tomei oil restrictor
ATI Harmonic balancer
Gates timing belt, tensioner and pulley all replaced in build.
Engine has been rebuilt, blueprinted, machined for 20 thou pistons and rotating assembly balanced. Block had been decked with all new welsh plugs.
Top end
Tomei Poncams 260deg 9.15 lift in and ex
Greddy cam gears
Timing Cover has been polished
1.2mm Tomei metal head gasket
Brand new rocker cover seals and half moon seals
Painted r34 Gtr red covers and plenum
Head has had a full recondition with all new retainers replaced on both sides, valve regrind and lifters serviced.
Engine comes complete with intake plenum, manifolds, all new hoses, r33 gtr sump, turbo oil/water lines, engine mounts, alternator and AC pulley and bracket. No injectors or rail or turbos, however can source parts and install on request.
Engine has been comprehensively inspected by a qualified mechanic, leak down tested, cooling system tested and compression tested, since removal. Has also been tested and run, is in perfect operating condition. Has been built for and used in a 300kw setup for drag purposes, perfect for track or street setup.
Price $8500
Located Gold Coast can Freight Anywhere Aus wide
PM or Call/Msg 0414596256
Edited by toy515
https://www.sau.com.au/forums/topic/433665-built-for-high-hp-rb26dett-for-sale/
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
