Welcome.
Assuming you have R33 turbo boxes it seems strange you are blowing them chasing 'only' 330RWKW. I say 'only' as that is still a lot of power for a street car, just no where near the limit of those boxes.
https://www.sau.com.au/forums/topic/433966-new-member/#findComment-7079981
Woops sorry, I assumed you had manual. Like Luke said swap to manual, cheaper than a built auto and more fun for a street car. Also manual is a plus if you decide to sell it in the future.
Lol, I have 2 of them one the exact same with minimal mods running manual, would be happy to make my modded one less streetable as it's not my daily and i'm sus on the 2nd gear set in the manual boxes from experience.
How strong are the manual box (clutch choice also dependant of course) and what sort of power figures have people been able to put through them?
https://www.sau.com.au/forums/topic/433966-new-member/#findComment-7087704
swap to manual.
or th400, or power glide.
Cheers, will do some more researching. Preference is always manual but it's still just as fun regardless what transmission is in it.
Just want some reliability without an 8k price tag.
Can pickup complete manual conversion for $1500 with good box tomorrow... But does that mean i'm going to be doing a clutch everytime I give it a bit of what for?
https://www.sau.com.au/forums/topic/433966-new-member/#findComment-7087710
Here is a quote from the CT forum. There are a bunch of guys on their using the 33 boxes for drag racing.
"i have a wrecker spec box with a short shifter i only put oil in it because it was empty in the frame of mine its cheap lets break it then think about something different it did 4 years on the road running in the 11s @ 130ish mph at the track then another 2 years of drag only running 10s @ high 130mph with full slicks and 6800rpm two step launch and still all good. It has been through 2 blown clutches, 1 smashed centre bearing, 3 broken uni's, 1 pretzal tailshaft, 2 folded lower control arms and then 2 broken axles. I pulled it down thinking i should look at the damage NONE wasnt even fillings in the oil THEY ARE TUFF "
Look at getting a Jim Berry clutch if you are worried about it failing. Twin plate should be under $1500. He will talk you through it and let you know the best clutch for your application.
https://www.sau.com.au/forums/topic/433966-new-member/#findComment-7087746
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
