Good evening all,
I was bored last night and during my channel surfing I come across tapout xt on the infomercial channel. It seems to be a cardio/ resistance type workout and was just curious if anyone has tried it. I also found some info on the rushfit workout as well so I thought I would mention it. I am a bit hesitant with everyone watching me at the gym while I die attempting some of there cardio workouts and thought maybe it would help enough to start out on. ( especially when I can get both cheap as ) Any thoughts would be greatly appreciated. Thanks All
https://www.sau.com.au/forums/topic/434040-rush-fit-tapout/
I have been going to the gym for about 8 months and trying to build muscle however I am short and stocky and i want to get more definition. Basically I wanna drop fat and build muscle which I am having trouble doing. I am seriously thinking about giving this a go to drop the body fat than go back to the gym
https://www.sau.com.au/forums/topic/434040-rush-fit-tapout/#findComment-7081284
I understand that rev. When I first started going to the gym my heart rate was 160 at about 6.5 km/ph on the runner. In the time at the gym I can now run 2 kms in under ten minutes as a warm up before I hit the weights. I have also stopped eating pretty much simple carbs as my diet pretty much consists of oats in the morning with a protein shake than chicken and brown rice for smoko lunch and pre gym snack ( sometimes with semi dried tomatoes and feta ) than after workout I will have a protein shake and than dinner which usually consists of sweet potato chicken/steak/kangaroo and lots of veges . Only on leg day will I have some potato after a workout as I usually am very wobbly afterwoulds with tea. I usually have one coffee in the morning with one sugar and occasionally a can of Pepsi max during the day.
https://www.sau.com.au/forums/topic/434040-rush-fit-tapout/#findComment-7081449
Ok that sounds like it's healthy and all good changes for the long term. You body composition will gradually change to reflect what you are now doing.
In terms of matching your requirements , it's about how much. So how much rice and how much chicken vs your requirements.
Plenty of people do similar to yourself and find changes are small and slow. If you are eating relatively large portions or too small it stalls progress.
Have you done a basic portion vs marco check?
How lean do you want to be and when are you wanting that to happen by?
Building muscle AND dropping significant fat is a challenge:
a) Because it's suibjective
b) Because the rates and potential are genetic (also see above)
c) Because packing on lots of muscle at the same time as dropping body fat is much harder than doing just one of them. Requires more commitment.
Rush Fit and Tapout infomercials feature the usual people who built muscle in the gym then did it for cardio. The lean bit they got from the kitchen.
https://www.sau.com.au/forums/topic/434040-rush-fit-tapout/#findComment-7081550
I have had a look at iifym and derived a sort of basis. I have a bowl of oats for breakie than breakup half a chicken to be divided into 3 meals and same as for a packet of brown rice ( I think 250mg divided into 3 ). I use the microwaveable packs as they just so convienent and than for tea I usually try have a good size of protein ( 250-350 gram steak or chicken etc) I am currently sitting 78 kilos and am 170 cm tall. I usually go to the gym 3-4 times a week. Ultimately I would like to grow some size but lower my body fat
Edited by Kenna802
https://www.sau.com.au/forums/topic/434040-rush-fit-tapout/#findComment-7081697
To be honest rev I don't really have an answer. All I know is when I look in the mirror I'm not happy . All I do know is I want to get abs I can see ( I have about an inch of fat hiding over my lower abs and about half an inch of fat over my middle ones as well as increase my puny arms and generally increase muscle all over. I know I have made gains in the 8 months I have been doing this as I have built up to 3 sets of 80 kilos at 6 reps each. When I first started I couldn't do that at 60kg
https://www.sau.com.au/forums/topic/434040-rush-fit-tapout/#findComment-7083587
You need to 'quantify' those goals. Numbers. Size measurements . You can go with waist measurement for example. Be realistic.
Seeing abs is one thing , however , if you have never seen them before your expectations are based on unknown. This leads to dissapointment.
Takes time to get lean, takes time to get fat. Be realistic but, commit to things that can be measured. The subjective puts you in danger of image issues even when you have achieved alot.
https://www.sau.com.au/forums/topic/434040-rush-fit-tapout/#findComment-7084809
    • Why are people so insistent on making dirty water?!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
