Attendees:
1. Cadmoon
2. t5iv
3. HiveFleetAbyss
4. NW007
5. cowdy
6. Cyifly
7. Bodo
8. Shi Pi
9. gts032
10. Kiwi_Phil
11. Kiwi_Phil's +1
12. ARE31
13. B-Boi34 +1
14. Bubbles
15. Tohmez
16. Ralf
17. Bubbles
18. Bubbles' +1
19. Wolfman101
What are you talking about? :whistling:
fixed...he's starting to get old and picky about the spelling :P
Attendees:
1. Cadmoon
2. t5iv
3. HiveFleetAbyss
4. NW007
5. cowdy
6. Cyifly
7. Bodo
8. Shi Pi
9. gts032
10. Kiwi_Phil
11. Kiwi_Phil's +1
12. ARE31
13. B-Boi34 +1
14. Bubbles
15. Tohmez
16. Ralph
17. Bubbles
18. Bubbles' +1
19. Wolfman101
hhhhmmmmmm why am I on here 3 times ?
does that mean I have to go around 3 times more than everyone else ?
I get the +1 but its up there as 14 &17 aswell ....... :unsure:
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
